What is a Servo ?
Results 1 to 2 of 2
Thread: What is a Servo ?
    Moderator ynneb's Avatar
    Feb 2004
    Oz
    Default What is a Servo ?
    A servo is a motor that can run just as effectivly in both clockwise and anticlockwise direction, it has an encoder attached to track its movement.
    With a controller card the servo can be driven to a position and hold that position.
    Many CNC machines use servos to drive the working tool into a desired position
    Being outside the square !!!
    Apr 2005
    Denmark
What is a Servo ?
What is a Servo ?
What is a Servo ?
