You should be looking for your
MTB Manual with alarm descriptions ......
A turret servo alarm is not a Fanuc alarm
We have a Johnford lathe with a fanuc oi-tb controller. the controller starts okay the gives a 1107 turret servo alarm. What should i be looking for?
- Need Help!- Using the touch-off probe in a Johnford Lathe 650A.
- Need Help!- Johnford TC-65
- Problem- Lathe JohnFord with Fanuc 18 - need help
- Need Help!- FANUC 0i for Johnford lathe 2 axis
- JOHNFORD VMC
*~~Darwinian Man, though well-behaved, At best is only a monkey shaved!~~*
*__________If you feel inclined to pay for the support you receive__________*
*______Please give to charity [url]https://www.oxfam.org.au/get-involved/______*[/url]
I realize that it's not a fanuc problem. there is not a mitsu turret board on this site, and I can't figure out what these people did with the manual.
Just throwing spaghetti on the wall. Thanks Monkey
OK A few more details wouldn't go amiss !!
I.E.
Machine Manufacturer + Model
Control Manufacturer + Model
Relevant Servo Amplifier and Motor Models
And a description of what is happening/not happening
With this info we can start to help
If it is a Mitsubishi Control I suggest you post this info in this forum
http://www.cnczone.com/forums/forumdisplay.php?f=111
i have the same problem.1107 turret servo alarm..its a johnford sl-500 with the fanuc oi-tb controller,it has the golden sun turret on it,i cant get the alarm to clear,or zero the machine out or anything...any help????thanks
We have found that this alarm can not be cleared until changing the 3.6v lithium battery located on the turret drive in the main cabinet out back. We do this battery change while the machine is powered up. After the battery is replaced we go through the turret resetting routine found in the machines manual.
