Hi toranacar,
It's controls memory and buffer clearance but also RS232 speed can causes problems, not CimcoEdit.
3D milling are tons of lines which can be a problem for older controls.
Regards,
Heavy_Metal.
Hi toranacar,
Regards,
Heavy_Metal.
No worries. I hope I don't get too many issues like this as the cnc will be coming soon.
on the machines with 0 type controller and that do not hae the tape mode swich will be no problem as you make DNC on and put on auto mode will wait for program coming from rs232.
indeed you can not see the program running on the screen like in the normal auto mode but you can always see :distance to go and one line that is executed.
So if you do not have the key for tape moe,do not worry,just make the DNC on,put on auto mode,start cimcoedit and send program to cnc and hit cycle start from machine.
Thank you mate.
You and the other guys really have helped me out.
Thank you very much
Sorry if I asked before but is there another software I can use besides cimco? I like cimco but just seeing what else is out there.
I had a quick look at
https://www.predator-software.com/Pr...re_Compare.htm
Predator CNC Editor Express - Predator Software Inc.
or
Predator CNC Editor - Predator Software Inc.
And Camsoft
Im guessing these software programs are similar to cimco but perhaps more modern versions??
toranacar,
I have liked DNC4u. Not to expensive to buy and you get any updates for free.
Cj
Cool
Thanks mate
Toranacar,
Hard to tell, it could be your main connection... but it is in an awkward spot IMO. Are there other big terminal blocks in the other cabinets?
Cj
"mains" swith should be installed. Follow the wires of the main switch.
yes good point, the connection block goes to main switch. Thanks mate
Curious that there is what appears to be a wire labeled "N" on that terminal strip as well.
Can you advise if those wires got to the top or bottom of the main breaker?
Usually the incoming goes directly to the disconnect (several codes and standards as to why). I have to wonder if that was possibly added for either a step down or isolation transformer.
My bad, new breaker switch was in the "off" position lol.
Hello everyone, I have a problem to activate DNC in fanuc O-MC, I have the following block in the ladder
X006.6 G127.5
How can I identify this input signal? I don't have a tape selector.
I would really appreciate your help, thank you
