Need Help! Fanuc 0M number and dripfeed? - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 58 of 58
Thread: Fanuc 0M number and dripfeed?
  1. #41
    Mar 2011
    Quote Originally Posted by Heavy_Metal View Post
    Hi toranacar,
    All standard (iso) nc-code can copied to CimcoEdit, when you backplot (simulation) the code it becomes "visible".
    You can use Cimco for DNC, but large programs by f.e. Mastercam can cause buffer problems on control side.
    Regards,
    Heavy_Metal.
    So the buffer issue can be resolved by editing in cimco or is it because my controller is old and lacking memory?
  2. #42
    Dec 2012
    The Netherlands
    Default Re: Fanuc 0M number and dripfeed?
    Hi toranacar,
    It's controls memory and buffer clearance but also RS232 speed can causes problems, not CimcoEdit.
    3D milling are tons of lines which can be a problem for older controls.
    Regards,
    Heavy_Metal.
  3. #43
    Mar 2011
    No worries. I hope I don't get too many issues like this as the cnc will be coming soon.
  4. #44
    Mar 2011
    Quote Originally Posted by zavateandu View Post
    if DNC is on you need nothing more as a rs232 cable and a software to dripfeed,i use cimcoedit ,really easy ,just set it up and go.
    Let the R and G now,you have to learn about it ,now you are too far for understand it.
    good luck
    I spoke to cnc technician familiar with this cnc mill mcv op Fanuc om controller.
    He said I would need to re configure the ladder as it has no tape mode. Does this sound correct?
  5. #45
    Mar 2011
    Hi toranacar,
    When you have CimcoEdit you have basic DNC functionality, maybe it's enough for what you want or what you need.
    Regards,
    Heavy_Metal.
    The programs I wish to do would be quite large. Quite a few contours etc drawn from mastercam
  6. #46
    Dec 2009
    ROMANIA
    on the machines with 0 type controller and that do not hae the tape mode swich will be no problem as you make DNC on and put on auto mode will wait for program coming from rs232.
    indeed you can not see the program running on the screen like in the normal auto mode but you can always see :distance to go and one line that is executed.
    So if you do not have the key for tape moe,do not worry,just make the DNC on,put on auto mode,start cimcoedit and send program to cnc and hit cycle start from machine.
  7. #47
    Mar 2011
    Thank you mate.
    You and the other guys really have helped me out.
    Thank you very much
  8. #48
    Mar 2011
    Sorry if I asked before but is there another software I can use besides cimco? I like cimco but just seeing what else is out there.
    I had a quick look at
    https://www.predator-software.com/Pr...re_Compare.htm
    Predator CNC Editor Express - Predator Software Inc.
    or
    Predator CNC Editor - Predator Software Inc.
    And Camsoft
    Im guessing these software programs are similar to cimco but perhaps more modern versions??
  9. #49
    Feb 2013
    toranacar,
    I have liked DNC4u. Not to expensive to buy and you get any updates for free.
    Cj
  10. #50
    Mar 2011
    Cool
    Thanks mate
  11. #51
    Mar 2011
    Hey guys, old thread.
    So after all this time i recently had a chance to position my Leadwell MCV-OP in my garage.
    First thing is to get an electrician to connect the 3 phase power.
    Can someone confirm this is the power connection in the bottom corner of the computer cabinet?
    Fanuc 0M number and dripfeed?-240571189_528556028441470_3834474539755278835_n-jpg
    Fanuc 0M number and dripfeed?-237785299_3028777080732420_7927024109145713156_n-jpg
  12. #52
    Feb 2013
    Toranacar,
    Hard to tell, it could be your main connection... but it is in an awkward spot IMO. Are there other big terminal blocks in the other cabinets?
    Cj
  13. #53
    Mar 2011
    Not that I can see.
    Looks like thats it.
    I was going to buy some 3 phase cable
    Fanuc 0M number and dripfeed?-240717176_373713827571367_324659016781618807_n-jpg
  14. #54
    Member Algirdas's Avatar
    Mar 2009
    United Arab Emirates
    "mains" swith should be installed. Follow the wires of the main switch.
  15. #55
    Mar 2011
    yes good point, the connection block goes to main switch. Thanks mate
  16. #56
    Curious that there is what appears to be a wire labeled "N" on that terminal strip as well.
    Can you advise if those wires got to the top or bottom of the main breaker?
    Usually the incoming goes directly to the disconnect (several codes and standards as to why). I have to wonder if that was possibly added for either a step down or isolation transformer.
  17. #57
    Mar 2011
    Hey guys hope all are well.
    So i got the 3 phase power connected, hope this picture tells a story?
    Issue is the machine appears to have no power at all. Like its dead. Might be something simple, might be something not so simple??
    Fanuc 0M number and dripfeed?-245412678_566080044467963_7307375816093242846_n-jpg
  18. #58
    Mar 2011
    My bad, new breaker switch was in the "off" position lol.
