Hello,
thanks for the prompt reply, Dan.
As I was so happy you answered, I went right back to the shop and checked.
I can confirm the cable connection as you described it. The old ribbon cable is disconnected from the mainboard. Instad the rainbow coloured one is connected to the BTR. Then there's a second one that goes via the HONDA plug on the outside and back to the CSQ-connector in side the cabinet.
The parameters are currenty set like this:
Parameter 24: 0 0 0 0 0 0 0 0
Parameter 25: 1 1 1 0 1 1 1 1
Parameter 26: 0 0 0 0 0 0 0 0
Unfortunately I couldn't download the PC-DNC editor by now.
I can neither send nor receive anything. Can I check whether the BTR is broken somehow?
Do you prefer me writing you emails instead, by the way?
Thank you,
Alex
By the way: do I have to change any bit on the setting page to activate this function?
We use and recommend from ebay
DNC ADVANCE. RS 232 To USB Reader. Drip Feeder DNC
that costs with sending $ 200
