As far as I know, you cannot drip feed an OM-A control. I have the same control and asked the same thing 5 years ago and was told it was not capable of drip feeding without spending a huge amount of money for an upgrade. My .02.
Hello Everybody,
I am Visu, a new member of the CNCzone forum.
I need help with Fanuc OMA control
I bought a Leadwell VMC with Fanuc OMA control. I am able to send and recieve fixed memory part programs from PC to CNC and vice-versa. I am unable to operate the drip feed mode
G127.5 is not listed in the ladder logic and there is no switch for tape mode.
Is it possible to enable the drip feed mode by altering the PMC
Thanks for any help
The 0M-A will not drip-feed. When Fanuc introduced the 0M-B, they added a bit on the I/O interface called "DNCI". If the machine tool builder puts some logic in the ladder to turn on the DNCI bit, then you're able to run in drip-feed mode. The 0M-A never had this bit, so there's no chance of making it work, even if you can edit the ladder.
If you had a 0M-B or 0M-C without a TAPE mode on the mode select switch, it would be possible to add the function by editing the ladder.
Hello
I have recently bought Leadwell VMC with OM-A and i wanted it to accept Drip feeding /DNC can any one help?
best regards
Bilal
Hi cmpcleveland, What is the fanuc control model?
check the line#127 of diagnostic screen, bit #5 if it is 1.
dear sir
i have fanuc 0ma control it dos not show g127.5 want to editing in ladder can i send you copy of e-prom
mukesh dhiman
e-mail sehmbi2000@gmail.com
+9109814042108
Hello Everybody,
I am mukesh, a new member of the CNCzone forum.
I bought a johnford VMC with Fanuc OMA control. I am able to send and recieve fixed memory part programs from PC to CNC and vice-versa. I am unable to operate the drip feed mode
Thanks for any help
Hello Everybody,
Thanks for any help
show G127.5 show this 00000100
Hello Everybody,
Thanks for any help
Interesting thread, I have a Leadwell MCV OP Fanuc OM. The manual I have says OMF
Hello please can you help me to enable drip feed on my Fanuc 0ma?
Thankyou
