How did you format the card?
everything going fine, running dnc from cf card. Reposted a program, reinserted card in remote mode, got this alarm. (OIMC control). Tried another card that was fine, same alarm. Restarted machine, reformatted card at PC, same alarm. I cant find "1010" alarm in the book, so I dont really know where to start. any help would be super!
It is the poor craftsman that blames the tool
This is just an alarm that tells you that you haven't put the card in properly. Normally you can pull the card out, press the reset button and reinsert the card and everything will be fine. But since you said you tried another card that was fine, then the next thing to look at would be the control card reader. It might be wrecked. Check the pins and make sure they are clean and not bent.
I just purchased cards made by kingston and they all give that same error, while our sandisk cards don't cause problems. Maybe manufacturer has something to do with it?
please format the card in FAT mode, copy again the programs u need and insert into the machine. If ur computer is free of virus everything goes well as per my experience.
I found that the cards made by Kingston on work if they are 2GB or less. The original Sandisk will work up to 4GB but I found Transcend Industrial to be one of the best cards to get.
Hi
Pls send more detail about your USB pen
I have problem on 1010 error now
Hello spock
Recently I have problem card Error 1010
Fanuc OI MB
So How you fix it.
If you can share tp me will be appreciated.
Charlie
Try formatting the card on the machine
Hi
I have format with machine.
It complete.
Then Restart.
Card error still there.
If I remove card and try to read data from Card.
Machine say. insert card."
Put card in.
Memory card Error:
Any point for looking?
Try a low-memory card.
do you have a 512mb card or an sram ?
Hi
I have 64 M and 2GB
Few days ago both work fine.
Probably your slot then they are about £40 from fanuc
Because of this reason only, some people use extension cord with the card, rather than directly inserting it in the machine.
You mean adapter for CF card? ( I have 2 adapter That get same Error )
My Machine Card slot is direct to Main Box of controller.
Easy to replace?
yes
You know, occurring an error is very much irritating and is useful too. Because these memory card errors use to remind us that something is going wrong and you have to solve such an issue as soon as you can. Well, you can fix memory card error 1010 by formatting your memory card with ease.
To get more information: http://www.rescuedigitalmedia.com/fi...ard-error-1010
