Need Help! Cannot delete file memory
Results 1 to 5 of 5
Thread: Cannot delete file memory
    Feb 2010
    Default Cannot delete file memory
    I have Fanuc OMA. Has 32K memory. Control shows it has "0" memory left but it will not let me delete programs in memory - says it doesn't have any files in memory.
    Is there a Parameter setting controlling this? And which one?
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Default Re: Cannot delete file memory
    Fanuc has a protected area where system files are kept away from the curious operator. The most common is the toolchange macro. These are in the O8000 to O9999 range.
    Memory would be used up & files not be able to be seen, UNTIL you un-protect this range.
    Once unprotected, carefully rename/delete or copy files. And restore the protected status of that area.
    Removing the wrong files can stop your machine from functioning correctly.
    I suggest doing a backup copy of parameters and macros whilst unprotected
    I am unsure of which parameter that controls this protected area.
    Feb 2010
    Quote Originally Posted by Superman View Post
    I have changed a few things in the Parameters over the years. Still gives me the "Shivers".
    Can you give me your version of how to backup the parameter etc. files? I am on a Mac
    Thank you for answering my queries
    Feb 2010
    I returned to machine yesterday. Done the delete with 0 - 9999 exactly same as had done before, this time it cleaned the memory and number of programs
    Dec 2008
    Antarctica
    Quote Originally Posted by donferg View Post
    Caution... if your program protect is not active, using the O-9999, will also delete any macros that the machine requires ie toolchange, probe stuff, etc.
