fanuc ex alarm
Results 1 to 3 of 3
Thread: fanuc ex alarm
    Member Artal15692's Avatar
    Sep 2024
    Default fanuc ex alarm
    I have a problem with a lathe on a Fanuc stand. After finishing the work, the machine returned to its original position, and something like a black screen with numbers appeared on the screen. I turned off the machine, and now it gives four errors. Could you help me figure out what these errors are and how to fix them?
    EX1100
    EX1009
    EX1008
    EX1000
    Attached Thumbnails Attached Thumbnails fanuc ex alarm-ff6e48d4-e282-435f-8888-3346c33b0eb0-jpg
    Member guhl's Avatar
    Aug 2007
    Russian Federation
    Default Re: fanuc ex alarm
    These alarms come from ladder. MTB programmed them. But usually text follows them.
    Look for description in manual for machine tool. Or upload your ladder file and probably we would reveal you a meaning
    Dec 2009
    ROMANIA
    Quote Originally Posted by Artal15692 View Post
    EX1100
    EX1009
    EX1008
    EX1000
    Is very important the first part of your message as a black screen is ussualy appearing on a Fanuc controller when is short on the 24v DC and the controller halt with black screen
    after you recover you have now some alarms that comes from the I/O unit-it means input/output module
    so i am guessing that a short from a wire blew up a fuse in a I/O module and you need to check and change it
    If the fuse will bow again it means that you still have a wire thta goes to the ground in the 24V DC circuit so you need a good electrician to chek it out
    good luck
fanuc ex alarm
fanuc ex alarm
