Need Help! Fanuc Series O-MD. Loss of air pressure when changing tool
Results 1 to 3 of 3
Thread: Fanuc Series O-MD. Loss of air pressure when changing tool
    Member IvoGil's Avatar
    May 2024
    Default Fanuc Series O-MD. Loss of air pressure when changing tool
    Hello,
    Could anyone be kind to help a newbe on this?
    We have a cnc in the workshop that run just one program, for one task only. Few weeks ago we had a air leak that lead to the machine to be stuck when changing tools. I have replace the air hoses but dont know how to overwrite the tool drum to go back to it’s origin point.
    Machine is a Eagle 1000, the software is Fanuc Series O-MD
    Attached Thumbnails Attached Thumbnails Fanuc Series O-MD. Loss of air pressure when changing tool-383327c1-4412-4e03-8009-68764ccbdedd-jpg   Fanuc Series O-MD. Loss of air pressure when changing tool-1cbef96c-cbde-458b-a5a0-530d17cc7c08-jpg
    Mar 2008
    Default Re: Fanuc Series O-MD. Loss of air pressure when changing tool
    There should be a push button or soft-key to jog the drum mechanism back to the Park position.
    Then you should be able to re-home the machine and manually unclamp the drawbar releasing the tool in the spindle.
    Dec 2009
    ROMANIA
    Must be some M-code for moving the magazine back to home
    I would strat looking in the program O9000 or O9001 for tool change where you will find the M-codes for moving foward and backward the magaizine
    If you do not see the program on screen,enable parameter 10 bit 4 from 1->0 and after finish put back to 1
    Good luck
