FANUC AC MAIN SPINDLE problem!!
Results 1 to 20 of 20
Thread: FANUC AC MAIN SPINDLE problem!!
    Nov 2007
    Croatia
    Default FANUC AC MAIN SPINDLE problem!!
    Hello all.
    We have FANUC AC regulator for main spindle type A06B-6059-K0311.
    On display we have error message AL-17.
    Regulator has display on main board and 4 buttons
    MODE UP
    DATA_SET DOWN
    We have checked all voltages (+24; +15; -15 and 5 V) are they are ok.
    Could anybody tell us what is ALARM-17.
    How to enter parameters and listing of parameters.
    Best regards !
    Member guhl's Avatar
    Aug 2007
    Russian Federation
    Quote Originally Posted by Cole84 View Post
    Hello all.
    MODE UP
    DATA_SET DOWN
    Best regards !
    I faced with same problem on the 10T control. But I do not remember model of spindle amp. My control displayed OT113 error and AL-17 was on the spindle amp. I received the quote on the forum:
    My notes say Alarm 17:
    (1) Meaning
    In the main circuit, the voltage at the DC link is abnormally high.
    A fuse of the AC reactor unit may have blown.
    (2) Cause and troubleshooting
    (a) An input fuse of the AC reactor unit has blown.
    → Replace the fuse.
    (b) Regeneration circuit failure
    → Replace the unit.
    Nov 2007
    India
    I searched the whole Fanuc Manual for the alarm AL-17.But no luck it was not there.The problem also occured on my machine wich has a Fanuc OT-D control.The problem was tht the serial pulse coder was malfunctioning later when we opened it an IC was blown this defective pulse coder gave wrong signals to the IGBT due to this the IGBT was also found defective. Please check the components of the spindle drive like the IGBT(spindle module).The serial pulse coder(encoder) wich is usually of 1024PPR or 2500PPR,check all its signals.After rectifying some defects in them the problem shud be solved.
    Nov 2007
    I had an AL-17 just this week and this is what I did to fix my problem
    How to initialize the memory (NV-RAM) on the AC Digital Spindle PCB.
    ALARM #17
    1) Obtain a current spindle parameter list from the Machine Tool Builder.
    (This parameter list was supplied by the MTB and should be with the machine.)
    2) Turn main power off.
    3) On the spindle board change the jumper setting "S1" from DRIVE to TEST.
    4) On newer spindle PCB, "SH" jumper must be set from DRIVE to SET.
    (Most spindle boards do not have this jumper setting.)
    5) Turn the main power on.
    You will see the 7 segment display changing as follows.
    (00000) to (11111) to...to (FFFFF) to (00000) etc.
    6) Push and hold down all 4 buttons (MODE, DATA SET, UP & DOWN)
    at the same time until you see (FFFFF) on the display.
    7) Push and hold down the (MODE) button, while pushing the (UP) or (DOWN)
    button until (FC-22) is displayed.
    8) Push and hold the (DATA SET) button until you see (GOOD) on the display.
    9) Turn the main power off.
    10) Change the "S1" jumper setting from TEST to DRIVE.
    11) Change the "SN" jumper setting from SET to DRIVE. (If board has jumper)
    At this point, the generic spindle parameters are set. Your machine will not operate properly with these parameters.
    The next step is to load the customized parameters back into your machine. The MTB parameter list is needed at this time.
    HOW TO CHANGE PARAMETERS
    1) With the main power off, set the "SH" jumper from DRIVE to SET
    2) Turn the main power on.
    3) Push and hold all 4 buttons (MODE, DATA SET, UP & DOWN)
    4) Push the (MODE) button, you will see parameter number (F-00) Release the(MODE) button to see the parameter contents.
    5) To change the parameter number, push and hold down the (MODE) button, and push the (UP) or (DOWN) buttons to scroll to the next parameter.
    6) To change contents of parameter, release the (MODE) button and push the (UP) or (DOWN) button. Change the value to the values on the parameter sheet.
    7) After all parameters have been changed, push and hold the (DATA SET) button untill you see (88888) on the display
    8) Turn the main power off.
    9) Change the "SH" jumper setting from SET to DRIVE. (if jumper is used)
    The spindle board has been initalized and the parameters reset. At this time your spindle should run.
    Nov 2007
    Croatia
    Thanks a lot m8 will try that
    Nice explanation.
    Nov 2007
    Croatia
    Now Duke was right i initialize the memory but i didnt get any parameters with machine so i will try to contac machine dealer and try to get parameters. If anybody have parameter or parameters description i would be grateful my machine is anayak-matic-9-cnc.
  7. #7
    Aug 2007
    Russian Federation
    To my mind type of machine does not very matter. The following text from manual for spindle amp. of Tsugami NP 32. But data for spindle amp. of Tsugami NU4Y are enclosed too.
    F00 - Motor rotation speed display
    F01 - Machine stand-by finish signal (MRDY) in use ("1") or not in use ("0")
    F02 - Speed override in use ("1") or not in use ("0")
    F03 - Setting of speed override setting range at 0 to 120% ("1") or at 0 to 100% ("0")
    F04 - Setting of speed command voltage ("0" when external analog commans are in use and "1" when DAC in
    use "0".
    F05 - Setting of highest rotation speed: in case of standart version 5000 RPM, ("0") 6000 RPM ("1"); in case of high-speed version 10000 RPM ("0"), 12000 RPM ("1"), 15000 RPM ("2"), 20000 RPM ("3").
    F06 - Setting pattern for output limit:
    discription pattern1 pattern 2
    No output limit 0 0
    Limit for acceleration/
    decceleration only 1 4
    Limit for normal ro
    tation only and not for
    acc/dec 2 5
    Limit for norm. rot.
    and for acc/dec 3 6
    F07 - Value setting for out put limit (the rated maximum output is 100)
    F08 - Delay-time setting until power to motor is shut off (delay time = set value x 40 msec)
    F09 - Power to motor shut off ("1") or not shut off ("0") depending on machine stand-by finish signal (MRDY)
    F10 - Speed error offset adjustment when forward rotation is set (SFR) is commanded
    F11 - Speed error offset adjustment when reverse rotation is set (SRV) is commanded
    F12 - Speed error offset adjustment when orientation (ORCM) is commanded
    F13 - Rotation speed adjustment for forward rotation direction
    F14 - Rotation speed adjustment for reverse rotation direction
    F15 - Rotation speed when speed command is 10V ( rot. speed = set value x 100 RPM )
    F16 - Detection range of speed attainment signal ( detection range = within the percentage (+/-%) value set in ralation to the command rotation speed
    F17 - Detection level of speed detection signal ( detection range = not more than the percentage (+/-%) value
    set in ralation to the maximum rotation speed )
    F18 - Setting of torque limit value (torque limit value = not more than the percentage (+/-%) value set in
    ralation to the maximum output )
    F19 - Setting of time required for acc/dec ( time = set value in seconds )
    F20 - Regenerative power limit (adjustment during dec.; setting range 0 to 100 )
    F21 - Setting of speed-control phase compensation "P" HIGH gear ( CTH = 1 )
    F22 - Setting of speed-control phase compensation "P" LOW gear ( CTH = 0 )
    F23 - Setting of speed-control phase compensation "P" at time of orientation: HIGH gear
    F24 - Setting of speed-control phase compensation "P" at time of orientation: LOW gear
    F25 - Setting of speed-control phase compensation "I" HIGH gear ( CTH = 1 )
    F26 - Setting of speed-control phase compensation "I" LOW gear ( CTH = 0 )
    F27 - Setting of speed-control phase compensation "I" at time of orientation: HIGH gear
    F28 - Setting of speed-control phase compensation "I" at time of orientation: LOW gear
    F29 - Adjustment of speed detection offset (adjusted at machine's time of shipment)
    F30 - Adjustment of rotation speed display
    F31 - Settig of rigid tap mode
    F32 - Setting of normal motor voltage
    F33 - Setting of motor voltage at time of orientation
    F34 - Setting of motor voltage during rigid tap mode
    F35 - Speed zero signal detection level ( detection range = not more than the percentage (%) value set in ralation to the maximum rotation speed )
    I have got 2 types of motors: model 8 (Tsugami NU4Y, NC - 10T) and model 6 (Tsugami NP32, NC - 0T). Give you settings for both types correspondently:
    F00 = blank, blank
    F01 = 1; 1
    F02 = 0; 0
    F03 = 0; 0
    F04 = 0; 0
    F05 = 0, 1
    F06 = 0; 0
    F07 = 100; 100
    F08 = 5; 5
    F09 = 0; 0
    F10 = 128; data depends on the type of machine. Refer to separate table of parameters (I can not see parameters right now, but manual says: normal setting is 128)
    F11 = 148; data depends on the type of machine. Refer to separate table of parameters (I can not see parameters right now, but manual says: normal setting is 128)
    F12 = 128; data depends on the type of machine. Refer to separate table of parameters (I can not see parameters right now, but manual says: normal setting is 128)
    F13 = 194; manual says that normal setting depends on the type of motor and data depends on the type of machine. Refer to separate table of parameters (I can not see parameters right now).
    F14 = 195; manual says that normal setting depends on the type of motor and data depends on the type of achine. Refer to separate table of parameters (I can not see parameters right now).
    F15 = 45; 60
    F16 = 15; 15
    F17 = 3; 3
    F18 = 50; 70
    F19 = 20; 10
    F20 = 70; 60
    F21 = 50; 50
    F22 = 50; 50
    F23 = 100; 100
    F24 = 100; 100
    F25 = 30; 30
    F26 = 30; 30
    F27 = 30; 30
    F28 = 30; 30
    F29 = 119; 128 (approx.)
    F30 = 0; 0
    F31 = 0; 1
    F32 = 10; 11
    F33 = 10; 10
    F34 = 100; 100
    F35 = 75; 75
    F36~F40 = 0;0
  8. #8
    Nov 2007
    Croatia
    Thanks Guhul for nice parameter description. Will try them and i will report did i solve the problem.
  9. #9
    Jan 2007
    italia
    hallo all. I have egal problem in my control fanuc O-M ac spindle A06B 6059 H206
    The machine JOnh Ford VMC 824
    I can used these parameters for my machine?
    I wait for your information.
    Thank you, see you later .
  10. #10
    Aug 2007
    Russian Federation
    Quote Originally Posted by politecnica View Post
    Only several parameters depend on machine settings. In general, you should look into whole spindle parameters meaning, then find out what kind of model of motor is being used and only then try to change them
  11. #11
    Nov 2007
    Croatia
    Talking
    I solved my problem after i got parameters for my machine. The procedure of parameter input was just like DUKE356 told to do only i havent got jumper SET-DRIVE.
    Many many thanks to GUHL and DUKE356.
    I will post my parameters soon.
  12. #12
    Nov 2007
    Croatia
    Smile Fanuc Spindle Parameters and description
    So these are the parameters for main spindle on A06B-6059-K0311.
    Parameter- Data- Description
    F00 0 Speed motor is dispayed
    F01 0 Signal (MRDY) is used
    F02 0 Use/No used speed override
    F03 0 Range of speeed override
    F04 0
    F05 1 Maximum speed
    F06 3 Output limit pattern
    F07 100 Limit output value
    F08 5 Delay time to motor inter.
    F09 0 Use/No use mrdy signal
    F10 124 Error offset in CW (SRF)
    F11 147 Error offset in CCW (SRV)
    F12 128 Offset in orien. (ORCM)
    F13 34 Adjust speed in CW (SRF)
    F14 34 Adjust speed in CCW (SRV)
    F15 50 Speed with 10 Vs
    F16 15 Detec. Range speed (SAR)
    F17 3 Detec. Range speed (SDT)
    F18 50 Torque limit value (TLMH)
    F19 10 Aceleration/Deceleration time
    F20 40 Limit regenerative power
    F21 50 Velo. Loop gain high gear
    F22 50 Velo. Loop gain low gear
    F23 100 Velo. Loop gain orient h.g.
    F24 100 Velo. Loop gain orient l.g.
    F25 30 Velo. Loop gain h.g.
    F26 30 Velo. Loop gain l.g.
    F27 30 Velo. Loop gain orient h.g.
    F28 30 Velo. Loop gain orient h..g.
    F29 160 Speed offset (Test TS3)
    F30 0 Motor speed indication
    F31 1 Rigid tap mode (TLML)
    F32 10 Motor voltage normal operat.
    F33 10 Motor voltage in orientation
    F34 100 Motor voltage in rigid tap
    F35 75 Detection R.P.M. N=0 signal
    F36 70 Detection range load
    F37 0 Time constant torque deceleration start
    F38 0 Control deceleration
    F39 0 Control stable rotation with no load
    F40 0 Control in torque limitation
    PARAMETERS WITH STANDARD VALUE:
    Parameter Data Description
    F41 64 Current loop gain
    F42 10 Slip compen. con.
    F43 16 Slip constant
    F44 10 Voltage compens.
    F45 5 Max. amplitude
    F46 30 Second. cur. const
    F47 8 Cur. estimat. const
    F48 71 Const. torque point
    F49 56 Excit. weaken. point
    F50 73 Volt. conv. const.
    F51 2 Gear 128=1 255=2
    F52 127 Cur.Conver. Const
    F53 11 Curren loop P gain
    These Parameters are from tabele. This motor type is 8S and there is 6S, 12S, 15S, 18S, 8P, 12P, 15P, 18P, 22P, 30P, 40P.
  13. #13
    Oct 2011
    thailand
    Dear duke356
    I'm Thank a lot for information
    Last time my machine fanuc 0t alarm al-17.
    Some step not used
    other step is ok
    thank
  14. #14
    May 2009
    Default A06B-6055-H106
    I wasn't able to access any parameters until I put the jumper into test mode. Once I did that it would flash from 000000 to 111111, 222222, 333333, 444444, 555555, 666666, 777777, 888888, 999999, AAAAAA, BBBBBB, CCCCCC, DDDDDD, EEEEEE, FFFFFF, back to 000000 and reapeat.
    When you held MODE it would only display FC-00 through FC-23, which I had no documentation on. After attempting to adjust any parameter (wouldn't let me change anything) I got to FC-21 (or 22?) at which point I hit the DATA-SET button and it flashed a "GOOD" message.
    Powered down machine.
    Changed the jumper back to DRIVE mode and powered the machine back up. It then showed the 00000 like it should! I held the MODE key and input F00 through F40 which were in my control documentation and everything works fine now (phew)!
    Note that I did home the machine before this worked, not sure if it matters..
    So now I'm worried the drive is on its way out, should I be concerned?
  15. #15
    May 2013
    wis9
    A06B-6055-H106
    alarm AL-07
    thank
  16. #16
    Aug 2007
    Russian Federation
    AL-07 "Velocitty of motor is exceeded to the maximum rated speed. (Digital system detection)."
  17. #17
    Feb 2013
    India
    Default Re: FANUC AC MAIN SPINDLE problem!!
    Thank u Duke for posting this info. But need further more assistance from you. When i tried to initialize the NVRAM...upto stage 7its OK with me. but when i tried stage 8 i.e holding and pressing data set button it never came in "Good" condtion even i waited long time. Insted of that it flashes AL-17. Even when i tried to insert parameter it not showing the parameter values.
    pls post on this as soon as possible.
  18. #18
    Registered KQHung's Avatar
    Oct 2014
    Vietnam
    Dear Guhl,
    where can I find the FF parameter? Is in the Yaskawa A1000?
    I want to turn the rigid tapping on. Landsides said turn FF31 to 1 but I do not know how to change this parameter.
    Thanks very much for your help!
    Hung
  19. #19
    Aug 2007
    Russian Federation
    Quote Originally Posted by KQHung View Post
    Dear Guhl,
    Hung
    may be they mean option parameter in CNC. what's your controller?
  20. #20
    Oct 2014
    Vietnam
    Quote Originally Posted by guhl View Post
    My controller is Fanuc OM-B.
