Need Help! Fanuc OM can't run M code in Memory mode
Results 1 to 2 of 2
Thread: Fanuc OM can't run M code in Memory mode
    Member namnp2009's Avatar
    Mar 2021
    Default Fanuc OM can't run M code in Memory mode
    Dear all.
    I have my trouble is: My CNC machine( it's using Fanuc OMC controller, with PMC axis control) can't run M-code from Memory mode, but I can let it run correctly in MDI mode.
    Does any one can guide me to fix this problem?
    Thanks for your help.
    Nam.
    Dec 2009
    ROMANIA
    Default Re: Fanuc OM can't run M code in Memory mode
    When you press the start cycle button is that lit(green color) or is not:
    1.If start button is not lit you must check the following:
    -diagnose 122 must be XXXXX001-means machine is in auto mode
    --diagnose 120 XXXXX1XX---this bit must be 1 when you press cycle start button
    -diagnose 121 XX1XXXXX this bit ia feed hold signal
    2.If the start button of cycle start is lit wth green colour but the machine do nothing check following:
    -diagnose 700--all bits on 700 line must be 0 if everything is ok,if any bit is 1 when you press cycle start on diagnose 700 line please come back and let us know what bit
    -diagnose 701 bit 5 XX0XXXXX must be 0 in normal operation
    Please check and let us know
    tibiafaraway's Avatar
    Dec 2023
    Quote Originally Posted by zavateandu View Post
    It seems this solution is absolutely correct. I believe it will work normally again
