Need Help! Fanuc 18i-TB - Change tool
Results 1 to 3 of 3
Thread: Fanuc 18i-TB - Change tool
    Member LuisSmith's Avatar
    Nov 2023
    Default Fanuc 18i-TB - Change tool
    Good morning, I have a problem with a Fanuc 18i-tb control.
    The lathe has a tool change by servo motor (A), the servo motor was changed for a new one and it asked me to make a reference, every time I want to use the servo motor it tells me "reference return incomplete"
    https://www.youtube.com/shorts/q6fQDrznQEA
    Attached Thumbnails Attached Thumbnails Fanuc 18i-TB - Change tool-imagen-de-whatsapp-2023-11-13-las
    Member cncmakers001's Avatar
    Jul 2011
    China
    Default Re: Fanuc 18i-TB - Change tool
    Quote Originally Posted by LuisSmith View Post
    The reference position return cannot be performed normally because the reference position return start point is too close to the reference position or the speed is too slow. Separate the start point far enough from the reference position, or specify a sufficiently fast speed for reference position return. Check the program contents.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Nov 2023
    I add another video on YouTube, to see if you can support me
    Attached Thumbnails Attached Thumbnails Fanuc 18i-TB - Change tool-imagen-de-whatsapp-2023-11-14-las
