Fanuc Control Options?
Results 1 to 10 of 10
Thread: Fanuc Control Options?
    Default Fanuc Control Options?
    I'm not asking for a way to hack Fanuc Control parameters. My question is about inspecting used machines before purchase. Is there an easy way to query the control to see what control options are or are not enabled? Such as looking up if a machine has certain features enabled or disabled such as Custom Macro, High Speed Machining, Coordinate Rotation, Canned Cycles...? Other than trying out a command and seeing if it works, or looking up specific parameter numbers that may be hidden and inaccessible. I know you can always call the machine manufacturer with the serial number, but they aren't always helpful and they may not know if it had been messed with.
    Apr 2009
    Default Re: Fanuc Control Options?
    Most (if not all) have the hardware configuration displayed on a SERVICE screen. The OPTIONS can be displayed on controls before 2007, but no information is displayed.
    Contact me cnc@tulipmemory for more detailed info.
    Dec 2009
    ROMANIA
    i can say to you what options are active if you send me the CNC ID NUM file for the new controllers ,you can punch it out on a memory card or usb-is the last menu when you navigate to the right side
    for old controllers i need the 900 or 9000 parameters
    zavateandu@yahoo.com
    Member gazmub's Avatar
    Jun 2023
    Quote Originally Posted by zavateandu View Post
    How can you tell from the cnc id num file?
    Jun 2023
    How can you tell what options are there based on the cnc id num file
    Apr 2009
    It is there in the diagnostics, but you need a cross reference list with the order #.
    The MAINTINF.TXT file has the order # of all options listed.
  7. #7
    hi friend
    i wrote a software tool can list the cnc option function after read the cncidnum.txt file
    Attached Thumbnails Attached Thumbnails Fanuc Control Options?-_20230702152205-jpg   Fanuc Control Options?-_20230702152212-jpg
  8. #8
    Dec 2009
    ROMANIA
    - - - Updated - - -
    Quote Originally Posted by gazmub View Post
    trust me i know
    send here a CNC ID NUM file and i will list you the options
  9. #9
    Dec 2009
    ROMANIA
    Quote Originally Posted by kelenew View Post
    hi friend
    hey
    from where you have the diagnose information for all the bits in diagnostic?
    i am very curious
    is the software for sale?
    can i buy it from you?
  10. #10
    hey
    i am very curious
    my email: kele225@163.com
