You either need to contact the OEM/MTB or find someone with the same machine, Fanuc 0TC means nothing, the parameters & ladder etc are unique to a make/ model of machine and are originally set up by whoever designed the M/C.
hello friends .
I'm electronics technical. maintenance electronics board and make modification and solution for old system. hardware and software. I have fanuc o-tc series control.i found some problems in hardware. 1st problem makes cut off for battery line. so it's lost parameters. My customer don't have back up to parameters just have the parameters manuals .
trying input all parameters manuals but didn't work also The operator's panel didn't work and unable chiose edit or automatic mode because this mode touch key's in The operator's panel not select switch. so I'm need back up file to sending it with laader or dnc to control. after it's working we can edit different parameters.
Fanuc series o-tc type -A02B-0098-B501
My email.electronis_elmostafa@hotmail.com
Thank you
How can contact OEM|MTB?
I'm read to 27c256 (oe1 and oe2)and saved this file .
And when erase this eprom and on The control give me massage 1- load pmc \3-run\4-run without pmc .and when press 1 Wait The file form pc. And I insert the diagnostic parameters 300-to 400 .but The control need packup file form PC
What is the make model of the machine?
Find out if still in business, if this was done with a private retrofitter, then you may have to get it recommissioned.
