Good morning I have a little problem with my Victor
VTurn 36
1998
Fanuc Series O-T
0669-07
Servo: 9046-09
PMC: OLSP-1
Can someone know what i must change in parameters.
Problem is when i use knob from rapid feed when i setup on 0% machine should stop but still going in Z and X 398-401mm/min and this is not rhigt because should stay stopped.
Knob is ok because feed is changed
Rapid Z X
0% 398 401mm/min
25% 3750 3000mm/min
50% 7500 6000mm/min
100% 15000 12000mm/min
All solutions which i found is for new Fanuc and this one don't have so much parameters numbers. Even if i do Rapid and Work feed on 0% machine stil slowly going till see in program G1 then stop because on work feed when knob is on 0% and is ok
I too, have O series control where 0% is not zero, it is about 1% of actual rapid rate....
The only way, to have a "zero" rate, would be to use "dry run" which uses feedrate override control which does go down to zero, the downside is the maximum override rate is a lot, lot less than the machine's rapid rate.
