Need Help! CNC cycle not running
Results 1 to 5 of 5
Thread: CNC cycle not running
    Jul 2012
    South africa
    Default CNC cycle not running
    Hi All,
    We had a machine breakdown where we found the I/O Link modules were faulty. We replaced this and also found some shorted wires that we repaired. What happens now is that the cyce start will not work. I see when we press the cycle start it gives a signal G7.2 to the CNC but the machine does not do any thing and no errors.
    I also see the output from the CNC F000.5 is not coming on.
    Can anyone advise what other signals I may require for the CNC to run its cycle?
    Jul 2012
    South africa
    Default Re: CNC cycle not running
    Hi All further to this. I checked G8.5 for feed hold and this is on.
    Dec 2009
    ROMANIA
    look in the ladder and check who is making G8.5 on and what is holding the feed
    Jul 2012
    South africa
    Quote Originally Posted by zavateandu View Post
    G8.5 Is supposed to be on. If it goes off then the CNC Signal resets. I am trying to find out what other signals I need to take a look at.
    Jan 2013
    england
    Quote Originally Posted by BrendanDixon View Post
    Hi All,
    Given your earlier I/O link issues and wiring short, I would go back over everything, checking every current input and output to the wiring diagrams. I would also check the safety relays and functions, door closed and locked signal, tool and work holding etc,
