XC609M SETUP OF AXIS MOVEMENT
Results 1 to 5 of 5
Thread: XC609M SETUP OF AXIS MOVEMENT
    Apr 2011
    phillippines
    Question XC609M SETUP OF AXIS MOVEMENT
    Hello all
    Im trying to set the distance parameter a axis will move but when i add decimal point to number it doesn't enter goes to single number.
    So has anyone experience in setting these up ?
    https://youtube.com/shorts/NSwxFMO2NxI?feature=share
    look here for vid
    Apr 2011
    phillippines
    Default Re: XC609M SETUP OF AXIS MOVEMENT
    Jan 2009
    It has to be a number between 1 to 999999999, no decimals because it's a motor pulse count.
    Apr 2011
    phillippines
    also same issue with next line axis rotation
    SparqLee's Avatar
    Jun 2024
    Quote Originally Posted by adriancampion View Post
    Write full lengts of numbers: examle if microsteping is 6400 and reduction ratio 3 you have 19200 steps per revoliution after reduction, Calculate full travel length per revoliution you mecanical part, if 1,5 mod have 4.71 mm pitch betwen tooths, with 15 toth, per revo you have 70,65mm convert to 70650 microns
    example
    p0188 19200
    p0189 70650
    for ball screw if mod is 5 mm per revo
    and microsteping 1600
    example
    p0188 1600
    p0189 5000
