You will need a spindle setting bar to sweep the bar diameter high point at zero/zero (for x zero) while rotating B axis B0 to B180. Y zero found by using gauge blocks under the bar from the table top and add the gauge block dimension to half the bar diameter to find Zero.
There is a procedure for this and when done correctly the numbers will be close to the original blue book values. Without B axis it's a different procedure using a table bung.
If you don't know how to do this, you'll need a few hours of time by a service tech.
