Not ready is usually to do with the emergency stop circuit. Many things could lead to it. Using the wiring diagrams check e-stop line continuity end to end, if open circuit, check each point along the circuit, rather like finding a break in a daisy chain.
It could be emergency stop switch or signal. End limit switch, air pressure, oil pressure, a 100v fuse etc.
