Send serial file directly to Fanuc motherboard. - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
Thread: Send serial file directly to Fanuc motherboard.
  1. #21
    Dec 2009
    ROMANIA
    Default Re: Send serial file directly to Fanuc motherboard.
    that is the diagnostic data starts from 300
    you can input the diagnose like the sam eway as parameters
  2. #22
    Dec 2012
    New Zealand
    Now I'm more confused.
    I have complete Parameter listing that came with the machine. What I have is
    N0300 P 00000000
    but when I skip through the parameters on the screen 0300 looks like a decimal value option not binary.
    See here.
    Send serial file directly to Fanuc motherboard.-0300_data-jpg
    The next question is, Tmr 1 located at D300 and has a value of 60000 from the printouts.
    The biggest number I can enter is 255.
    The timer address numbers step in 5's so I assume that 60000 would cover a few registers.
    Maybe D301 = 75
    D302 = 235 (235 * 255 = 59925)
    Lastly D560 - 565 are keep relays and have a few binary settings
    The screen shows more like drive parameters
    Send serial file directly to Fanuc motherboard.-0560_data-jpg
    so not sure what to do here.
  3. #23
    Dec 2009
    ROMANIA
    you are looking in the wrong page
    you need to be in the diagnose page
    you send pictures from parameter page
    Send serial file directly to Fanuc motherboard.-wrong-jpg
  4. #24
    Dec 2012
    New Zealand
    My mistake. I've never paged down far enough in the diagnostics to see the other registers.
    It won'l let me enter 60000 in D0300.
    Send serial file directly to Fanuc motherboard.-d0300-jpg
    Maybe I can download it.
    On the otherhand some of the PNC must have been automatically populated . I never entered the tool numbers.
    Send serial file directly to Fanuc motherboard.-d0500-jpg
  5. #25
    Dec 2009
    ROMANIA
    yes ,the diagnose can me entered exactly like paramaters
    you can upload it by cable also
  6. #26
    Dec 2012
    New Zealand
    Cant enter by hand or cable.
    Looks like these are protected. Any idea on how to unprotect ?
  7. #27
    Dec 2009
    ROMANIA
    before entering the diagnose change the parameter 19 bit 7 ,restart the machine than send by cable
  8. #28
    Dec 2012
    New Zealand
    According to my OMD manual Parameter 19 bit 7 is DBCD. If = 1 the timer/counter values shown in Decimal
    If = 0 then binary.
    The original value was 1000 0000.
  9. #29
    Dec 2012
    New Zealand
    I can't believe that 1100 people have looked at this post. What an active forum.
    I have some movement on the machine when I press and hold the EM button. I get a contactor come in and then a servo error 434. On the drive, I get A -> Z drive. Maybe the brake is stuck or not releasing.
    However in researching faults, errors etc, I'm wondering if I can reprogram the EPROMS. The ladder logic has been disabled for viewing.
    I have a complete set of listings but having the option to view, I’d be in a much better state.
    So is the viewing ladder option in the EPROMS or in the diagnostics.
    Here are some of the options from the printouts.
    R597.1 PAS ENT PASSWORD ENTER
    R597.2 PASLDR PASSWORD FOR LADDER DISPLAY
    R597.3 LOOSET MACHINE LOCKING SET
    R597.4 PASCAN PASSWORD CANCEL FOR TIME OUT
    R597.5 LDRENT LADDER ENTER
    R597.6 CANENT LOCK CANCEL ENTER
    R597.7 LCSETV LOCK SET VALUE
    R598.0 LCSET2 LOCK SET VALUE
    R598.1 LCSTR1 LOCK START AUX1
    R598.2 LCSTR2 LOCK START AUX2
    R598.3 LCSTR3 LOCK START PULSE
    R598.4 TMOUT1 TIME OUT 1
    R598.5 TIMEOU TIME OUT
    R598.6 PSCAN PASSWORD CANCEL
    I presume the original EPROMS are copy protected. If not whoohoo. I then have to find out how to bypass the diagnostic lock if that is what it is. What software can I use to view and edit the ladder?
    Making parts with the machine is great, but getting it to run wakes me up each day. Oh dear I'm an engineering nerd.
    Should I start an new post with EPROMS ?
  10. #30
    Dec 2012
    New Zealand
    Which are the FANUC eproms and the machine builders ?
    Send serial file directly to Fanuc motherboard.-eproms-jpg
  11. #31
    Apr 2009
    The two on the far right are the ladder eproms; the system ones are below.
