G81/G83 can cycles on 0T
Results 1 to 9 of 9
Thread: G81/G83 can cycles on 0T
    Jun 2016
    Default G81/G83 can cycles on 0T
    Is it possible to use G81/G83 can cycles on 0T? We cannot seem to figure this out. Machine is a Hardinge Conquest lathe. Parameter change?
    Nov 2007
    Canada and Nothern ireland
    Default Re: G81/G83 can cycles on 0T
    On a lathe on Z axis drilling try G74
    Dec 2005
    I run an 0TA control on a SZIM lathe. As lshingleton mentioned, you'll want to use G74.
    You may find this handy:
    https://www.helmancnc.com/simple-cnc...rilling-cycle/
    Member guhl's Avatar
    Aug 2007
    Russian Federation
    Parameter 909#3 usually opens this option
    Dec 2009
    ROMANIA
    Quote Originally Posted by guhl View Post
    Please do not show option paramater in public
    you have to do it in private
    Please read the rules
    Will not be a next time
    cheers
    Member CNCRim's Avatar
    Feb 2006
    How old is the machine? older machine probably not have it at all.
  7. #7
    Community Moderator RaderSidetrack's Avatar
    Apr 2018
    East Tennessee
    Quote Originally Posted by zavateandu View Post
    cheers
    I'm posting this message as a CNCZone Moderator.
    I, and several other Moderators, are not aware of a rule that says "option parameters" can not be posted in CNCZone threads. We would welcome a link to such a rule, or further explanation.
  8. #8
    Flies Fast Superman's Avatar
    Dec 2008
    Antarctica
    Quote Originally Posted by RaderSidetrack View Post
    Oh-oh
    You cannot fathom the can-of-worms you have just opened
    Hope your pockets have lots of cash to pay the suits from FANUC for allowing propriety info to be displayed on a public forum
    You may as well say its OK to allow ppl to put up pirate software links for CAD or CAM wannabes
  9. #9
    Dec 2008
    Antarctica
    Found the rule....
    Posted by CNCAdmin as a "Sticky" @ the top of Fanuc forum
    https://www.cnczone.com/forums/fanuc/53037-cnc-software-4.html
    I suggest the "Moderators" take a refresher at their rules & regs.
