Fanuc 16iM, on a robodrill, won't M99 repeat, won't even GOTO1 to N1
I have a robodrill w/APC and am trying to run a program
O0001 (CHANGE PALLET CALL PROGRAM)
(SET PROG NO FOR EACH PALLET IN QUICK NC)
M65
M98 P#990
M01
M99
this runs, but doesn't repeat (i am expecting it to repeat forever).
I also tried
N1
M65
M98 P#990
M01
GOTO1
M99
but, to me at least shockingly it doesnt repeat
any robodrill / fanuc guys out there know why this might not happen?
my next move is to call this program as a subprogram using M98, but the factory pallet call program from kawatatec is as shown above, so M99 should be working on this machine, but it just isn't.
Re: Fanuc 16iM, on a robodrill, won't M99 repeat, won't even GOTO1 to N1
this one is solved. it had nothing to do with the pallet call program.
it was my part programs, which get posted out of my cam software with an M30 at the end. since this pallet change call program is calling those part programs as a sub program, the end needs to be M99 instead. changing from M30 to M99 in the part programs solved it
