Need Help! Colchester Storm A90 Jog mode stops spindle.
Results 1 to 5 of 5
Thread: Colchester Storm A90 Jog mode stops spindle.
    May 2006
    Default Colchester Storm A90 Jog mode stops spindle.
    I have a Colchester Storm A90 with the Fanuc 21i-t control. It also has the simple control panel as shown in the picture.
    Here is the sequence of events....
    CUSTOM GRAPH --> MDI
    MDI: G97S500M3;
    CUSTOM GRAPH --> MANUAL
    JOG
    Spindle stops. Not particularly useful, to me at least. Is there a parameter or option that can be enabled to make the spindle stay on so I can face a piece of stock using the jog mode? Or turn a simple diameter without having to use the hand wheel?
    Attached Thumbnails Attached Thumbnails Colchester Storm A90 Jog mode stops spindle.-manual-screen-jpg   Colchester Storm A90 Jog mode stops spindle.-colchester-control-panel-jpg
    Dec 2009
    ROMANIA
    Default Re: Colchester Storm A90 Jog mode stops spindle.
    As far as ia know you can input the spindle speed in MDI but in jog mode you need to start and stop the spindle by push buttons
    It is normal to stop the spindle when switch the modes .it is just waiting to push the spindle foward or reverse and increase or decrease the spindle speed by override
    May 2006
    zavateandu, you are correct in the normal operation. However, since I have the stripped down control panel I don't have spindle start/stop button(s). I was curious if there was an alternate way to do the same thing. If not, then I'll continue as I have, but I would love to figure something out.
    May 2016
    United Kingdom
    When you select jog on any Colchester the spindle stops.
    It's written in the ladder so there is no way using parameters
    Apr 2011
    Post your ladder file
