Should be possible, what is the system?
Greeting!
FANUC DC SERVO MOTOR (Yellow Cap) A06B-0641-B013 3000M
Pulse coder fanuc A860-0300-T003 3000P
I have a problem with the pulse coder ( x axes). The glass came off and peeled off the marked part on te plate.
There is no way to fix it...
I have not been able to find another replacement encoder in my country as mine is 3000 pulses, is there any possibility of fitting a 2500 pulses one? If the parameters were changed? How easy is it to do? The encoders are physically the same, even the number tag, the only difference is the pulses.
A replacement encoder would be, if possible A860-0300-T002 2500P
