Fanuc 0TD Phase sequence - if I get it wrong what happens?
Results 1 to 2 of 2
Thread: Fanuc 0TD Phase sequence - if I get it wrong what happens?
    Mar 2017
    Default Fanuc 0TD Phase sequence - if I get it wrong what happens?
    Hi I have a new lathe Fanuc 0-TD controller. As title suggests, if I flick the on switch and the phase sequence is wrong could I destroy the machine?
    I was going to turn on the mains power briefly, check the coolant pump rotation, and reverse if need be.
    Dec 2003
    Default Re: Fanuc 0TD Phase sequence - if I get it wrong what happens?
    Normally the machine will not power up if the phase rotation is wrong, until corrected.
    But IIRC the 0 controller itself does not require correct phase rotation as the earlier systems do.
    Only the 3ph motors external to the system.
