Originally Posted by
drdos
You are basically screwed. 18i-LNB is a LINE Transfer Control which plays by different rules. You will have to replace the hardware (Main board) with a standard 18iMB (18iTB in case of a lathe). You will have to create the ladder yourself and address all of the I/O. The only big issue I see will be the Fanuc option bits. If the controller is newer than 2007 (Either this LNB or the replacement one) then you will have to get Fanuc involved with enabling any options that you may need. There is no guarantee that Fanuc will even entertain doing something like this.
