Need Help! fanuc 10m rs232 connection with pc
Results 1 to 1 of 1
Thread: fanuc 10m rs232 connection with pc
    Member igediz's Avatar
    Jun 2022
    Default fanuc 10m rs232 connection with pc
    Hi! I am using a Dahlih mcv 610 machine with fanuc 10m control unit. My problem is connection with pc. I want to send big programs with flow control.While the machine is in read mode,i send the program but nothing happens.i am using a software named Cncedit.After i sent the program,in the machine menu just the read sign flashes.The machine does nothing.I dont know where is the problem? The machine parameters or in the software settings or rs232 cable?I am using these parameter settings and these software settings which i found them from inthernet.I uploaded the wiring diagram of the rs232 cable and the software which i am using.I dont know what to do.Can anyone help me who has some information about these kind of problems.
    Here is my e-mail if you want to help me:
    igediz@outlook.com
    Thank you!
    CNC Parameters:
    Setting screen:
    Punch code- ISO
    TV CHECK=0 OFF
    Under Service page
    0020 = 2 (Input device Foreground)
    0021 = 2 (Output device Foreground)
    0022 = 2 (Input device Background)
    0023 = 2 (Output device Background)
    5001 to 1 (Device Select)
    5002 to 2 (RS232 Device Select)
    5110 to 3 (Device type DC Codes used)
    5111 to 1 (1 stop bit)
    5112 to 10 (4800 baud) 11=9600, 9=2400, 8=1200 7=600 6=300
    Software settings:
    1.01- Port Type: Standard
    1.11- Baud: 4800
    1.12- Data Bits: 7
    1.13- ASCII Even
    1.14- Stop Bits: 1
    1.15- Handshake: XON/XOFF
    Attached Thumbnails Attached Thumbnails fanuc 10m rs232 connection with pc-rs-232-png   fanuc 10m rs232 connection with pc-ads-z-png
