Fanuc O-M Leadwell CNC mill 086 P/S alarm - Page 3
Page 3 of 3 FirstFirst 123
Results 41 to 53 of 53
Thread: Fanuc O-M Leadwell CNC mill 086 P/S alarm
  1. #41
    Member machinehop5's Avatar
    Aug 2009
    Default Re: Fanuc O-M Leadwell CNC mill 086 P/S alarm
    Quote Originally Posted by toranacar View Post
    I have checked and unchecked it.
    So I should keep it checked?
    XON/XOFF Checked ..yes.
    a quick way to look for your USB Com port is in Windows Device Manager is ....Hold down the "Windows Key" on your keyboard then hit "R". then type "devmgmt.msc" and hit Enter or click OK
  2. #42
    Dec 2009
    ROMANIA
    [QUOTE=toranacar;2515674]
    Quote Originally Posted by zavateandu View Post
    ussualy you use 0 as channel
    stop bits 002#0 menas parameter 2 bit 0 ,like XXXXXXX1
    zavateandu, so does this mean i should punch in 00000001 in Parameter 002?
    yes
  3. #43
    Mar 2011
    OMG guys I'm so happy! I actually loaded a program aaaah my neighbours think im mad when I yelled out lol.
    Today is actually my birthday. Awesome birthday present thanks guys.
  4. #44
    Mar 2011
    And thank you for your patience. I'm not familiar with the technical side of this but finally made it this far thanks to you guys.
  5. #45
    Mar 2011
    These are the settings and program i loaded.
    The odd thing is the program number is in reverse?? Not a big deal, shouldn't affect program
    Fanuc O-M Leadwell CNC mill 086 P/S alarm-290003849_964380490897358_5333267012239464694_n-jpg
    Fanuc O-M Leadwell CNC mill 086 P/S alarm-290108418_1195002561338840_5951812026138980513_n-jpg
  6. #46
    Mar 2011
    I'm wondering how to set the tool and work offsets?? I haven't used Fanuc before, I think this is the right area on the machine for work and tool offsets but not sure on the procedure.
    Fanuc O-M Leadwell CNC mill 086 P/S alarm-290316499_3383954595194516_2471571144188549130_n-jpg
    Fanuc O-M Leadwell CNC mill 086 P/S alarm-290363924_406783498048445_3599830955826352487_n-jpg
    Fanuc O-M Leadwell CNC mill 086 P/S alarm-291059664_579866750518351_131226004559853300_n-jpg
  7. #47
    Aug 2009
    ...that's good news and Happy Birthday too.
  8. #48
    Aug 2009
    Yes, lose of parameters, then reloaded but i couldn't get the tool changer to work which is where it started.
    So i kind of gave up on the tool changer and just wanted to load a program and this is where i am now. If I can just get the program loaded ill be happy.
    ...Dear Happy Camper you mentioned you had the Parameters on a FD....was there any other Files on the FD that might be for Tool Changer? I'm not a Fanuc guy but, I do recall something about 9000 Programs/Marcos are used. These would be written by the MTB to interface M Codes etc needed. Start a new thread maybe for TC problem.
    DJ
  9. #49
    Mar 2011
    thanks mate.
  10. #50
    Mar 2011
    Yes i have it on floppy.
    Im not sure about the 9000 parameters.
    Yes good idea, ill start another 2 threads come to think of it. One for ATC and one for work and tool offsets for Fanuc as its a little different from HAAS which is simpler and what I'm used to. HAAS is literally one button for "tool offset measure" and another button for "origin"
  11. #51
    Aug 2009
    Default ReNumbering Program
    ...its a problem with your Post Processor looks like.... need to delete the (Parentheses) around the program number. The Control (I think) ignored that Line (O1000) and assigned O0001 to the file after Inputting from the PC. I was reading about in Chapter 8.4
    http://servicetex.ru/wp-content/uplo...0%BA%D0%B0.PDF
    snip:
    When a program is entered without specifying a program number.
    ? The O–number of the program on the NC tape is assigned to the
    program. If the program has no O–number, the N–number in the first
    block is assigned to the program.
    ? When the program has neither an O–number nor N–number, the
    previous program number is incremented by one and the result is
    When a program is entered with a program number
    The O–number on the NC tape is ignored and the specified number is
    assigned to the program. When the program is followed by additional
    programs, the first additional program is given the program number.
    Additional program numbers are calculated by adding one to the last
    program.
    Attached Thumbnails Attached Thumbnails Fanuc O-M Leadwell CNC mill 086 P/S alarm-fanuc-0m-program1000-jpg
  12. #52
    Mar 2011
    Default Re: ReNumbering Program
    thank you
  13. #53
    Mar 2011
    Just an update
    I've been busy and side tracked as my car broke down but that's another long story
    So the programs are loading fine and the machine is working (Minus the ATC) i realised the spindle is getting hot and i suspected the oil pump wasn't working and it certainly wasn't. I pulled the pump motor out and directly connected it to 240 volts and the shaft hardly turned, looks like gears are stripped.
    Just wondering where i could buy this motor or should i just buy the whole pump with container assembly????
    Sankyo motor MPDA40ZA01
    Fanuc O-M Leadwell CNC mill 086 P/S alarm-298917421_389077573332092_4980692958861372845_n-jpg
