I think setting parameter 12.7 and 1005.7 to 1 for the A axis will do what you want.
Hello, I have a Fanuc 21-mb machine and I need to disable the 4th axis - (A)
I already tried to change the parameter 9900 - the machine does not allow to change, asks to restart it, does anyone know how to solve this problem?
sorry for the translation, I'm from Brazil and there is no good forum like this one
- Need Help!- How to disable the Windows on Fanuc 160is
- Need Help!- Fanuc 6 TB G28 disable parameter ?
- Problem- Axis disable in fanuc 31i- madel A5
- Need Help!- Fanuc OTT C Axis Disable - URGENT HELP PLEASE
- Need Help!- Fanuc 16i-M 4th axis disable
I did this procedure, the parameter 1005.7 was already set to 1 and 12.7 was not, when I do this, the alarm 401 appears - servo alarm : z axis vrdy off
Are the Z and A axis on a common / dual axis drive?
If they are what is the drive part number?
There may be another parameter involved in case of dual drive.
Hi all,
I'm facing a 4th axis alarm issue, but since we don't use this axis, I need to get the machine up and running. Could anyone please advise me on how to disable it?
Thank you.
Hello a_v_c
PN 1010 controls the No. of axis Controlled by CNC. So if you need to Disable 4th Axis , put ( Existing Value - 1) in this Para.
If you need to Disable any axis in Between you need to modify PN 1010 / 1020 / 1023 accordingly.
hope it helps
