FANUC CABLE 19 pin connector cut off need help with configuring Color code
Results 1 to 6 of 6
Thread: FANUC CABLE 19 pin connector cut off need help with configuring Color code
    Default FANUC CABLE 19 pin connector cut off need help with configuring Color code
    Hi guys I have this purple cable from a DMG DECKEL MAHO (fanuc control) (fanuc handy Mac hand wheel , A02B-0259-C2210
    Cut off from the female side of it
    The side that connects to the CNC control
    Part number HR22-12TPD-20S
    Wondering if there is someone out there with the same machine or cable and if you can help me with Ohming out the Color code and which is which
    Much appreciated
    Dec 2009
    ROMANIA
    Default Re: FANUC CABLE 19 pin connector cut off need help with configuring Color code
    Hope it helps
    FANUC CABLE 19 pin connector cut off need help with configuring Color code-cable-jpg
    Attached Thumbnails Attached Thumbnails FANUC CABLE 19 pin connector cut off need help with configuring Color code-cable-jpg
    Quote Originally Posted by zavateandu View Post
    Hope it helps
    thanks so much for this
    do you have the same exact machine ? or which manual is this from? year, publication, etc?
    Dec 2009
    ROMANIA
    This is not from manual
    Good luck
    Good luck
    do you know anyone who can fix these cables? on here i have all the parts but i need the female plug to be soldered according to the print
    let me know if you know or any one who knows of an electronics repair technician please contact me
    thanks
    Dec 2009
    ROMANIA
    why you do not order a complete cable from Fanuc?
