Startup sequence
How do i solve this error codes?
Im a beginner with fanuc and cnc machines.
Startup sequence
Those error codes are displayed through the ladder (PMC) and caused by inputs (X address'). Given there are several and they don't seem to tie directly to one another based on the text, I would suspect either a loose common wire/connector, tripped breaker, or fuse.
The electrical schematics will definitely aid with this one.
Hello, there was one tripped fuse for the control panel, so now all the light on the control panel are working and near all the error codes are gone.
But I also get one new error code.
All the batteries was bad so I changed these, but I forget to do it with the machine powered on so now I have to return the axis to zero/home position.
What do I do now?
I tried to move the axis but when I press the floor pedal and on the jog buttons nothing happens.
1st thing to be done is clear the emergency stop state (EMG). That should clear the reset state and allow you to continue. Depending on the fuse that blew and the cause worst case is some inputs or outputs got damaged. Lets hope for the best.
If releasing the Emergency stop button does not do it directly there may be another button (master start, machine on etc) to push. If not there is an electrical / logic issue preventing the control from coming out of e-stop.
If that is the case you will need to reference the schematics to check the e-stop string.
