i was doing some work on the machine after completion of the program i turned off it for some time then i turned on the machine x and y dislocates. every time i turned it on but the offsets seems same.
please help me.....
When you say the axis dislocates. Are you referring to the home position not repeating / not being correct?
If not, could you detail the symptoms a little better.
