- probing Z calculation
Allo,
Maybe someone knows this function...
On Fanuc 18i and 21i controls, when using the renishaw probe in Z, i get 2 conditions.
Allo machines store the touch value at #5063
Some machine require current offset to be substracted.
#5063-#5083
Others can use the value as is...
#5063
This seems like it could be a parameter setting, but it escapes me.
Any of you have seen this issue?
I appreciate your time!
Thanks.
- You may not post replies
- You may not edit your posts
Forum Rules
