Were is the machine at now ? Home position ?
Any other alarms like APC ?
Machine cord?
DEAR SIR,
I need the help urgently, we have controller install on FANUC Series 18i-MB , installed on dahlih DCM 2213, controller having error 501 -z axis over travel. kindly need help plse help me I will be thankful to you.
- ZT2500 , MSG-501 , Not displaying X axis for upper turret
- News WARDJet Releases 5-Axis Router with 3 feet of Z-Axis travel
- Need Help!- SH-403 with MSG-501. Need set zero point for X-axis.
- need Z axis design advice- dahlgren engraver -> full Z axis- how much Z travel?
- Need Help!- U Axis excess error + Y axis over travel?!!!
Machine cord?
Power Down and press and hold the P and CAN buttons while powering up. Hold till you see normal screen.
Dear Ishingleton,
yes its in home position , but when we ran the program , it gives alarms - z axis over travel, there is no other alarms , APC & MACHINE CORD .
On the 1815 Screen have you reset the Z axis home position ?------------You changed the Z axis drive you would need to reset this ?
Dear Ishingleton,
Actually machine is coming to home position and taking all the reference, but our programmer active the ATC arm and it got stuck then this error came , after that we manually close this arm and after that now after running the program 300mm - z axis give alarm, and we have not change any drive or any thing.
Check Value in Parameter 1320 0r 1321 as these should be your negative value numbers ?
After you recovered the ATC arm does it require a one manual cycle to remove interlocks ?
When machine goes into ATC condition it is going through a set routine and some of that is to limit axis movement ----------Can you send the machine to ATC position and do a tool change ?
Is there a manual sequence button ?
Confirm tool in spindle is correct one after completing first cycle
PS what actual machine is this -3 axis mill but what manufacture and is there a ATC revovery sequence ?
In the ladders you would be looking for ATC squence completed signal
Check manual for complete atc recovery if you have it ?
Dear Ishingleton,
Have a good day, we have a problem in parameter settings now the problem looking to be solved , thank you for your time and help
You are welcome and good luck
