- Need Help!- Tool changer is not aligned to spindle
Good morning, We have an Anderson Exxact Router and the tool changer is not aligning to the spindle. Does anybody knows who to fix this? Thank you!
Re: Tool changer is not aligned to spindle
How is the alignment off?
If the axis is high or low and G28 is used as part of the exchange routine you may have jumped a grid.
The tool hits the outside of the spindle, unfortunately is about 1/8 off from center
- You may not post replies
- You may not edit your posts
Forum Rules
