Looking for a program example , that the programs turns on the cutting conditions . Anything from an O,P,Q or WO ,W1 should work . I can manually do it yes , machine works looking to do it inside the program .Thanks for any help you can provide .Thank you.
I figured it out if I put an S1 it will call up cutting condition 1 and S2 call store condition 2 so once the table is populated they can be called from within a program .
