WIRE EDM PROBLEM
Results 1 to 2 of 2
Thread: WIRE EDM PROBLEM
    Member gabedrummin's Avatar
    Aug 2008
    united sates
    Default WIRE EDM PROBLEM
    Had a battery alarm replaced the batteries and alarm will not clear .It appers as the two wires on the bottom battery box have become cut ??? Machine was working the night before...Machine is a elox O wire edm with a OM Fanuc controller .It uses AC servo motors and drives . Can any one help .Need wire schmatic of lower battery box . Had a 336 346 alarm 0 voltage absolute pulse encoder alarm for u and v axis . I made the machine think its a two axis machine to run parts but need to fix this can anyone help ?
    Aug 2008
    united sates
    Default Re: WIRE EDM PROBLEM
    Problem solved .
WIRE EDM PROBLEM
WIRE EDM PROBLEM
