Need Help! Loop Fanuc Oi
Results 1 to 1 of 1
Thread: Loop Fanuc Oi
    Member monteiro92's Avatar
    Dec 2021
    Post Loop Fanuc Oi
    Hi
    I'm new to the subject, and would like to create a one-repeat loop for a program like this, using IF, WHILE, GOTO.
    I'm work with a mazak milling VCP 400S.
    G17 G21 G40 G80 G94 G98
    G91 G28 Z0
    G57 G90
    M72
    M116
    G52 X-39.9 Y86.381 Z10
    T1 M6 (DRILL 1.30MM)
    S4900 M3
    G43 H1 Z100
    G0 X0 Y0
    G0 Z-28
    G83 X-8.5 Y-6.2 Z-53 R-45 Q30.0 F300 M8
    x-24.5
    x-41.5
    x-57.5
    x-74.5
    x-90.5
    x-107.5
    x-123.5
    x-140.5
    x-156.5
    x-173.5
    x-189.5
    x-206.5
    x-222.5
    x-239.5
    x-255.5
    x-272.5
    x-288.5
    x-305.5
    x-321.5
    M9
    G52 X0 Y0 Z0
    G80
    G91 G28 Z0
    G56 G90
    T2 M6( screw thread 1.40MM)
    G43 H2 Z100
    G0 X0 Y0
    G0 Z-28
    G98 M29 S682
    G95 G84 X-8.5 Y-6.2 Z-4 3R-49 F0.3 M8
    x-24.5
    x-41.5
    x-57.5
    x-74.5
    x-90.5
    x-107.5
    x-123.5
    x-140.5
    x-156.5
    x-173.5
    x-189.5
    x-206.5
    x-222.5
    x-239.5
    x-255.5
    x-272.5
    x-288.5
    x-305.5
    x-321.5
    M9
    M117
    G52 X0 Y0 Z0
    G80
    G91 G28 Z0
    M30
    I want to use the coordinates used in the drilling to make a thread without having to repeat each one using IF or WHILE.
    I can use GOTO to return to block x-24.5 but I don't know how to tell it not to repeat again when it encounters GOTO again.
Loop Fanuc Oi
Loop Fanuc Oi
