Hi I'm working on a dugard hd1886l with a omfi controller been trying to use g68.2 and it keeps coming with error 5459 and I cannot seem to find anything anywhere about what it is
Thank you for your help in advance
The parameter No. 19665 to No. 19667, No. 19680 to No.
19744 for configuring the machine are incorrect.
- The axis specified with parameter No. 19681 or No. 19686 is
not a rotary axis.
- In parameter No. 1022, the basic three axes are not set.
- A rotary axis end point found by the NC with tool center point
control type 2, 3-dimensional cutter compensation type 2, or
the tilted working plane command is not within the range set by
parameter No. 19741 to No. 19744.
- No rotary axis end point was found with tool center point
control type 2 or 3-dimensional cutter compensation type 2.
Check the machine configuration and specification.
- On a machine whose rotary axis is a virtual axis, tool center
point control type 2 or 3-dimensional cutter compensation type
2 was specified.
- When programming is performed in the workpiece coordinate
system, tool center point control type 2 or 3-dimensional cutter
compensation type 2 is specified.
