Need Help! About parameter problem
Results 1 to 3 of 3
Thread: Need Help! About parameter problem
    Member dongZ's Avatar
    Nov 2021
    Default Need Help! About parameter problem
    Hi everyone,
    I am looking for an old machine parameters backup, Can anyone tell me are those 9000 parameters ?
    And how can I check or read 9000 parameters? how to know those parameters are lost? If those parameters are lost, what happened to the machine? Thanks.
    N9000P2
    N9001P2
    N9002P8
    N9003P2
    N9004P2
    N9100P00000000
    N9101P00100000
    N9102P00100010
    N9103P10000000
    N9104P00000100
    N9105P00000100
    N9106P00000000
    N9107P00100010
    N9108P00100001
    N9109P00000000
    N9110P00000000
    N9111P00000000
    N9112P00000000
    N9113P00000000
    N9114P00000000
    N9115P00000000
    N9116P00000000
    N9117P00000100
    N9118P00010000
    Dec 2009
    ROMANIA
    Default Re: Need Help! About parameter problem
    These parameters define the options installed on the machine,like type of the PMC,how memory is enabled,some cycle functions,etc
    These parameters are unique for every machine.
    As i see must be and old machine with Fanuc 10,11,12,15 controller
    These parameters must be entered in hex
    Tell us the machine type and Fanuc controller and maybe we can get a copy of your parameters
    Nov 2021
    Thank you zavateandu,
    It is Fanuc 15-TTA control. The machine is Seneca Falls Model CD-600 .
    4 Axis Hollow Spindle Lathe.
