Need Help! Mori Seiki SV-500
Results 1 to 5 of 5
Thread: Mori Seiki SV-500
    Aug 2015
    Default Mori Seiki SV-500
    Just got called to see this machine. It doesn't start when pressing the start button first thing in the morning. After several minutes, it starts as if nothing was wrong. Owner doesn't have maintenance manuals. I've done an exhaustive google search to no avail. I need the ladder to see how the start circuit is set up.
    If anybody has a copy or pdf files, please let me know.
    Regards
    rlarios
    Dec 2009
    ROMANIA
    Default Re: Mori Seiki SV-500
    You ean start tje power to cnc or start the cycle auto?
    Jul 2017
    This sounds like a power supply issue. The problem will be which one.
    Check optional equipment. Could be something is leaving the EStop circuit open until it starts up. Like the spindle chiller.
    Aug 2015
    Quote Originally Posted by zavateandu View Post
    You can turn power on with main power switch. Fans start but when you press the start button on operator's panel nothing happens. After a few minutes, you press the start button it chimes and screen comes on. When it's cold it takes longer.
    Aug 2015
    Quote Originally Posted by PNaedele View Post
    I'll do as you say. I'll check power supply.
    If you have a schematic of starting circuit I will really appreciate it.
Mori Seiki SV-500
Mori Seiki SV-500
