Need Help! Reset part counter
Results 1 to 5 of 5
Thread: Reset part counter
    Member Heiro15's Avatar
    Oct 2020
    Default Reset part counter
    Greetings, I am looking for some guidance I have a fanuc series Oi-TD machine. Where I need to implement a counter for finished pieces. But this counter I need it to reset at an specific hour. How can I do this using PMC? Or what is the best way to do it?
    Default Re: Reset part counter
    Look at the operators manual under "Parts Count Display, Run Time Display". Depending on what exactly you are tying to accomplish this may suffice.
    You could also create your own counter using macro variables and a sub to increment, reset, or preset it whenever you choose.
    Member bumzag's Avatar
    Jun 2021
    I’m not sure there is a parameter that contains the current time of the machine
    For a 0i-TD, parameter 6710-6752 contains integer values of the count of machine parts along with operation time. If you’re able to use those parameters in your G code you might be able to make something work
    Apr 2011
    Post the ladder file and we can make the modifications
    Member Hardplates's Avatar
    Oct 2019
    #3012
Reset part counter
Reset part counter
Reset part counter
