Need Help! Can't set om controller from mm to inch.
Results 1 to 3 of 3
Thread: Can't set om controller from mm to inch.
    Aug 2012
    Unhappy Can't set om controller from mm to inch.
    The battery went dead on our old mill with om control. I cleared the control and reloaded all parameters and diagnostics (we had these backed up)
    Everything appears to be working fine except I cannot change the system to inches. Using the handy page setting, it will not change from 0 to 1, with or without pwe enabled.
    When I input G20 in mdi, it gives me alarm 10 (invalid G code)
    Any thought from the experts here?
    Aug 2011
    UK
    Default Re: Can't set om controller from mm to inch.
    Quote Originally Posted by rgrow1 View Post
    Please check you have the option parameter switched on 900 bit5
    Jun 2021
    Am I not mistaken or can't you just press the Offset key, go to the Setting page and change the relevant option from mm to inch?
