Hello, I'm stuck on something related to FOCAS function.
By using the cnc_rddynamic function in Kapware, I can get information such as positions, spindle speed, feed rate from CNC. For example if you look at the picture(figure1) below you may see that I am getting actual speed.
However, I want to use this function on visual studio with the help of C#, not on Kapware. I wrote my code by looking at the technical document as seen in the picture below. The program did not give any errors, but I always read the value 0(figure3). However, when I look with Kapware, I see some values (figure 1).
I think I'm making a logical error somewhere in the coding (figure2). Is there anyone who can help with this.
