FANUC 10T TURRET SPEED SLOW DOWN?
Results 1 to 5 of 5
Thread: FANUC 10T TURRET SPEED SLOW DOWN?
    Dec 2009
    ROMANIA
    Default Re: FANUC 10T TURRET SPEED SLOW DOWN?
    if the turret is controlled by a servo motor can be done but we need more info about the type of Fanuc and info about the servo drive
    If the turret is controlled by a hidraulic motor you need to adjust the speed from the flow of the oil.
    Sep 2009
    macedonia
    The Fanuc is FS10TF
    The turret is mechanical powered by small motor 0.4kw
    Quote Originally Posted by zavateandu View Post
    Attached Thumbnails Attached Thumbnails FANUC 10T TURRET SPEED SLOW DOWN?-img_20211027_135630-jpg
    Sep 2009
    macedonia
    Hi
    I solved the problem. Install frequent regulator and change the speed from 50Hz to 30Hz. Now the turret work slower but without any noise.
    Quote Originally Posted by tano View Post
    The Fanuc is FS10TF
    Member cncmakers001's Avatar
    Jul 2011
    China
    Hi
    That's clever.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
