Hello friends
I have a leadwell mcv 1000ap device with fanuc o-m model f
Produced in 1990
In this device, the parameters can be transferred to the device and computer
The G-code program can also be transferred to the device memory
But it is not possible to send the program from dnc software such as cimco and run it by the device
Thank you for your help
Do you see a "Tape" or "DNC" mode selection on the operators panel. The old membrane style panels were nearly impossible to re-label so it is possible an un-labeled button will select DNC/Tape mode.
You can check the ladder for G127.5. This bit on (1) in conjunction with Auto mode places the control into DNC/Tape mode.
