Need Help! ALARM AL-11 on Fanuc A06B-6059-H206#H550
Results 1 to 3 of 3
Thread: ALARM AL-11 on Fanuc A06B-6059-H206#H550
    Apr 2016
    Spain
    Default ALARM AL-11 on Fanuc A06B-6059-H206#H550
    Hello guys ,
    I have a fanuc spindle drive A06B-6059-H206#H550 and when starting it AL-11 goes out.
    I changed the transistor modules with new ones but the alarm continues to appear, i check the input power voltaje its ok 210 VAC
    Some ideas on how to solve the problem ???.
    Dec 2009
    ROMANIA
    Default Re: ALARM AL-11 on Fanuc A06B-6059-H206#H550
    the alarm is related to the DC link output power that is too high,there is no related to transistors.
    the problem is in your power PCB of that spindle drive
    Member freakycnc's Avatar
    Apr 2012
    not to overlook the obvious but next to the voltage selector switch (220/200) on this unit is F5 and F6. One or both may be open. Remove from ckt - with power off - and check.
