Need Help! Takisawa TC-1 Fanuc 0-TC PMC parameters
Results 1 to 5 of 5
Thread: Takisawa TC-1 Fanuc 0-TC PMC parameters
    Member bip1988's Avatar
    Sep 2021
    Default Takisawa TC-1 Fanuc 0-TC PMC parameters
    Good evening all, first time on here.
    I have a 1993 TC-1 that has had its parameters deleted. I have all the parameters that were punched out, however the PMC parameters 900-939 weren't recorded. If anyone has a copy it would be much appreciated.
    Regards
    Brad.
    Attached Thumbnails Attached Thumbnails Takisawa TC-1 Fanuc 0-TC PMC parameters-takisawa-tc-1-jpg
    Apr 2009
    Default Re: Takisawa TC-1 Fanuc 0-TC PMC parameters
    parameters 900-939 are options, The PMC parameters are called DIAGNOSTICS (parameters 300 on).
    Sep 2021
    Thanks for your response. Sorry, my mistake. In the print out i have there is a gap between 899 and 940. So i have the Parameters excluding the 900-939, also I don't have the diagnostics settings.
    Sep 2021
    I have managed to source some parameters/diagnostics for this machine. The issue i have now is that the ones I received appear to be for an 8 tool turret, however I have a 12 tool turret. Any idea which parameter/diagnostic number this may be?
    Dec 2009
    ROMANIA
    try with diagnose 440,450,455 to set up the 12 tools
    Peacock88's Avatar
    Oct 2020
    Thank you zavateandu.
    I have found out that on this machine it is D435.7.
    Once the machine is confirmed running ok, i'll look at posting an updated list for the PAR and DGN.
