AFAIK the 900 options are the same for both, send me a PM with an email address.
I have a VMC equiped with fanuc OM-C. It's Parameters got lost. Presently I looking for it's option parameters # 900. I have a backup of it's parameters but it does not contains 900 parameters. I would much appreciate for sending me option parameters along with every parameter bit description. Can I use Fanuc OM-D's 900 parameters instead of OM-C. Kindly help me to solve this problem.
For future reference, if you press and hold the EOB key, then press output/start, whilst outputting parameters, the 900 parameters will also be punched.
send me an email I will send you a pdf file for all the Fanuc OM C parameter
i have hmc with fanuc omc. on screen x y z axis are display. but B axis is not display on screen. In B axis drive - is comming. In servo tuning menu B axis is not display. 8400 series also not display. i think B axis is by passed. can you pl guide me ?
machineryclinic@gmail.com
Somebody can send me the parameters for 4th axys !!! Pleaseeeeee
Enviado desde mi GT-I9300 mediante Tapatalk
hello sir i have tongil tnv-80 with fanuc 0-m 1989 model yesterday during working my machine stop and show spindle stop alarm .
i think power fault is occur. then i resatrat and check all breakers many time but my z axis and spindle is not working. only x y axis is working.
by mistake i enable pwe and i/o parameter and restart machien with reset button . but i lost my all parameters .
now my machine show x y z axis param alrm and my mode is stuck in mdi mode please help me to send 900 to 933 parameters value to unlock my mode system
i m waiting for ur reply hassan jika.
hassanis321@gmail.com
https://www.facebook.com/hassan.jikanism
i have kryle KVC7 with OMC fanuc but the parameters are lost. can u plz help me.
my email id is : vikas.engineering1981@gmail.com
plz reply asap
Hello: I'm in need of 900 parameters for a FANUC OM-C controller also. It's a Mitsubishi gear hobber. Model G15CNC.
Thank you in advance.
Send PM with email
Thank you Al, for the 900 Parameters. I think I may also need PMC, and NC parameter files for this machine. Would anyone have a backup to share?
Thank You
hello, i also need the 900 parameters for the OMC. Mine is the simple version with one cpu doing NC and PMC. theres no seperate PMC and Graphics card. Its a retrofit with no tool changer. I have the regular parameters but didnt know that extra buttons were needed for more parameters. I could also use an explaination of the Diagnostic parameters since those wernt backed up either. I guessed at some stuff and got the machine to home but many things dont work. Digital spindle is not talking to the control, single block wont turn off, tool unclamp non functional, and lube pump only works in manual mode. Ill PM my email for any info you can send my way. I called Fanuc and they said its all proprietary and they can send a teem to me to reprogram my machine. It didnt sound very economical.
Sent
I also have a 0M-C that is acting strange. It won't allow me to edit any programs. The CAP soft key doesn't show up or the program list. I should be able to see the list of programs and hit "search" then the program number and input. At least that's how my other Miyano TSV's operate. This machine is new to me and someone may have tampered with the option parameters. Program protect key does toggle the correct bit. I have a 900 parameters list but there are a lot of blank spaces with no explanation. Any help would be greatly appreciated.
Dear fellow enthusiasts I have a full backup of an OMC vmc Victor Vc 80, if anyone needs a copy, please ask!!
Alguien me puede enviar una copia del manual de parámetros 900 para un Fanuc OT
See post #9 you have your private message shut off.
Al
